May 21, 2012, 06:50:41 PM
KT Lim
Strida 5 - Sport
Test Ride the Strida 5
Topic: Test Ride the Strida 5 (Read 3436 times)
Strida Singapore
Administrator
on:
April 19, 2007, 11:47:55 PM »
Strida 5 is finally here in Singapore! We are even earlier to get MK5 than parts of Europe and UK and parts of Asia!
To test ride the Strida 5, kindly contact Steven or Vivian at 6396 6280 for an appointment.
Last Edit: June 07, 2007, 01:54:33 AM by baru
boolee88
Newbie
Re: Test Ride the Strida 5
Reply #1 on:
April 22, 2007, 11:19:01 AM »
I was comparing the specs between the Strida 5 & Strida 3.3. Besides the black spokes & grips, I don't see a big difference.
What's the main difference between the two?
coolthought
Verified Member
Reply #2 on:
April 22, 2007, 01:42:36 PM »
Quote from: boolee88 on April 22, 2007, 11:19:01 AM
One simple way is, just make an appointment to take a look at both Strida together...loh
Or....
Check out this thread
http://stridasingapore.com/forum/index.php?topic=225.0
Chop! has own and ride on both the Strida 3 and Strida 5.
A key difference that most people won't notice is that the freewheel is now on the back wheel.
And....
Black - no difference
Blue - different
Bike Weight: 22 lbs (10 kg)
Frame: 7000 series aluminium
Handlebars: Biologic Grip
Drive Train: Kevlar greaseless belt drive
Bottom Bracket: Alloy welded
Wheels: Alloy 16" (41 cm) with
black spokes
Tires: Kenda Kwest 100 PSI high pressure tyres with reflective strip - the Singapore Strida 5 comes with these tyres.
Brakes: Cable Disc Brakes
Speed: Single speed (56 gear inch)
Folded Size: With performance kit: 45" x 20" x 9" (114cm x 51cm x 23cm)
Reflective Strip: Scotchlite
Bell: Nuvo Level Bell Mini
Rider Specifications: Weight limit: 250 lbs (110 kg)
Height: 5'4" to 6'4" (163 to 193cm)
Strida Luggage Bag: Comes with original Strida padded carrying bag
(this excludes the trade-in and/or discount programme for Strida Owners).
Last Edit: April 22, 2007, 09:24:24 PM by baru
coolthought
Verified Member
Reply #3 on:
April 24, 2007, 09:31:06 AM »
What about the Akslen rear Light with reflector?? Any difference from Strida 3?
